68 vs 69 Benchseat Interchange
GTXperience
Orig Stealth Mod
Sacramento Area, CA
I have still been on the search for a front split benchseat for the '69 Dart and one popped up locally. Besides skin patterns, what are the differences (if any) between a '68 Barracuda split benchseat and a '69 Dart split benchseat? Are the seat adjusters/tilt mechanisms the same (and in the same locations)? Also, will the tracks off of a non-split back benchseat (out of a '68 4-dr) work properly on a '68 split benchseat? I don't see why not but thought I would ask. TIA.
4 door bench seats are put together different . The sections wont interchange wih 2 door bench. The traccks are the same.
Thanks Red. The only parts I was curious about (between a stationary benchseat from a 4-dr and a split benchseat from a 2-dr) were the tracks. Now that you have confirmed they are interchangeable, I only need to figure out if the split bench from a '68 Barracuda is the same as the one in a '69 Dart.
68 &69 are the same except for the skins
67 is different in non-locking backs only
