Get a carb rebuild kit and go through that carb because you need a new accelerator pump plunger anyway. I'd also do the fuel pump test where you route the fuel pump output line into a container, crank the engine, and make sure a strong stream of fuel comes out. You should have 8 volts at the + side of the coil with the key in the run position engine off. If you have electronic ignition go to a local parts store and get another one. You should be carrying a spare anyway. I always ask for one for a '74 Dart 318 just so I don't have to explain the conversion kit etc. I have had great luck with the standard auto parts store replacement ignition modules. Voltage regulator and ignition module must be well grounded.
I checked the voltage at the + side of the coil, engine off, key in the run position, and I have 6 volts there.
George,
If I'm not mistaken yes, there's supposed to be an oil slinger on the crank snout. Mainly used to keep oil out of the front crank seal. Also if I'm not mistaken, one of the retaining bolts for the camshaft retaining plate has a hole drilled through to spray oil on the chain assy.
Yes, new points and condensor in the dist.?
OK, so no squirters squirting gas yet you can't blow thru the inlet. Take some gas in a squirt bottle, squirt the gas down the vent tube sticking up on the side the accelerator pump plunger is on. Enough so you get a at least a few tablespoons or more in the tube. Then work the throttle lever and see if the accelerator pump will squirt out the gas you just put in it. IOf in fact it won't squirt than, pull the top off the carb again as you a week or so ago. See how much fuel is in each bowl area. If there's no fuel in it you know you have a delivery or carb problem. If there's fuel in it, take note of where the linkage is connected onto the accelerator pump, pull out the screw holding the "S" linkage to the acc. pump and take off the pump. Look at the cup area of the pump. Check the bore area of the acc. pump cavity. Put the pump in the bore, put some gas in the bowl and pump the to see if you can get the gas to squirt out the squirters. You should be able to make them work doing that.
You should do a fuel pump pressure and flow check. Both running thru the inline fuel filter!
A sign of a bad ballast resistor is: It will start while cranking but, almost as soon as you let off the ignition key with your fingers it will die.
Hay Buddy, I know sometimes it can be frustrating! You have such a sweet car there just step back and take a break! I'm going to guess you didn't get to take the kids to school or pick them up in it. Bummer. Sorry.
A few other things. After it dies, do you have a way to have someone crank it while you watch for spark? What color is the spark while cranking? Will it jump a 3/16" or 1/4" gap if you hold the coil wire close to a ground? It should and it should be bluish and strong an bright. (battery must be in pretty good shape for the test).
A few ideas there.
Kim
Yes Kim, points/condenser/cap/rotor/plugs and wires all new.
I pulled the ballast resistor off the firewall to look behind it at the coil. The back of the resistor is sealed, meaning you can't see the coil itself, but there was no discoloration on the back of the resistor or the paint on the firewall. I never let the car idle for more than about 4 or 5 minutes at a time.
I went back and read your first post and it almost sounds electrical. I would check voltages at the ballast resistor and the coil then check the ohms value of the resistor. If the car has idled a lot the resistor can really heat up. Everyone here has offered good advice.
I checked the ground at the voltage regulator with my tach & dwell meter, and the green wire shows 12 volts, just like the battery. I think from all this cranking the battery is slightly low on voltage, although it still cranks over quickly.
I'll have to look up the voltage requirement for the ballast resistor, but if I understand this correctly, there should be 12 volts going in, and 8 coming out? As I said, there is only 6 volts at the pos side of the coil.
The rest of the tests for fuel delivery will need to be done after I reassemble the front of the motor, but I have to buy the oil slinger before I can do that.
I'll take the top of the carb apart again, and fill it with fuel for the accelerator pump test.
Please don't give up on the thread guys, I need all the help I can get! LOL
Thanks for all the help so far. I would have set the thing on fire by now.
George
