Daves69
Here a couple of shots of the nick in the pressure plate housing. This happened in 4 or 5 places I believe.
??maybe this if the cover is similar size.....................
The OP has done this but only after intitial contact! I wonder if a spring has been broken or tweaked on the disc!
Instead of the slappers, have you tried bolt on spring clamps just behind the front eyes?
Put a gopro under it from multiple angles and get some insite and piece of mind. Still wonder about the original impact of the pressure plate when you had clearence issues. It makes me concerened more for a spring on the disc than an imbalance on the hat.
I took that whole clutch assembly back apart and reinspected everything. All the springs were in good shape on the disc. Had a few friends of mine looking at it too.
How is it when you drive it like you stole it? Maybe it just wants to be unleashed all the time![]()
Curios? Does it have the front torque boxes as well as the rear? Only reason I ask is I have seen a certified factory 440 car that did not have rear torque boxes! Seemed far fetched to me but someone certified it!
Still think you ought to record what's going on with a camera, they can be indispensable!
Do you have an adjustable pinion sunbber under there? I just added one to my dart & boy that makes a diffrence! Biyes real good now & seems to have less shuddering on take off too. My twin 10 from mcleod has a bit of chadder on take off too but still within the bedding milage now. But the snubber helped a lil for me.
Yes it does have the rear torque boxes.
I haven't been able to procure a camera. Best I've been able to do is look under the car while someone is launching forward. So much shaking going on it's hard to tell what the source is.
What about the front boxes? I don't think it has anything to do with your problem, just curious!
I've got torque boxes forward of the front rear leaf hangers. Is that what your asking?
No.
Up front at the back end of the front fender splash shields. From the rocker to the front frame rails! I am thinking all 4-speed 340/383 cars have them or should from the factory!
