69 dart conv rear window regulator help?
toyval
New Member
melb australia
help please. I have a 69 dart convertable thats almost finished.Thing is the rear window regulators.Are they the same as the two door hard tops?You would think yes right, but we have a pair out of a hardtop that just dont line up .Its like a different shape all together.Being a dodge I would not of guessed that it would be different due to expense, but they have a different window and stuffed if we can figure it out.Also its the only known genuine conv in Australia so there is nothing to compare to.Pics or advise will help and get her on the road.
Quarter window regulators in convertibles are completely different from all others. It is the easiest to work on too.
If you can't find a 67 up Dart or Barracuda vert donor over there, someone over here should have them. I've seen them on ebay before. Hope this helps
Thank you both very much.Looks like it could be a hard find.Besides ebay and year one can anyone sudgest where to buy these from new or used?Thanks again.
Go to the wanted section and post an add. You might try Moparts .com , Donti's. BE/A restoration. Wild Cats in Oregon STATE. There are a couple big pick yards in Texas. Good luck
