[WANTED] 69 dart frt sway bar bracket
Bennoel 10
Toronto, Ontario
Looking for a 69 frt sway bar bracket pass side.
Mine is damaged as picture shows. Would also take a outer loop piece that was reproduced at one time but can't seem to find who or where.
Thanks for any help or suggestions.
Can’t really tell by the picture but you need to cut them to get new bushings in can that be welded up, or is it to far gone
If you look closely you should see half of the bracket still attached to the k-frame. The part that you describe that gets cut off to replace the bushings is the piece I need. Someone was reproducing them at one time but can't seem to find. Thanks
