69 dart headliner reproduction.. Best one??
1969ProDart
Florida
Who has purchased a reproduction headliner and which one has the best quality. Thanks.
i got a vinyl headliner from classic industries that i just installed in my dart. Fit was good with extra material. Only complaint i had was the idiot installing it pulled his lower back (goes back to heating pad)
Is this for a restoration?
The reason I ask is you can have something much nicer for far less work. I used a 73 and newer hardboard liner I appholstered with modern headliner material. Piece of cake to install (even with a cage) Looks great and has more headroom.
What about the sail panels, 73 and up hard board has them?
i got a sheet of panel board at the local home depot for 8 bucks and copied the one i had and voila i had two sail panel boards.
Also used the door seal adhesive to glue down the panel boards.
I used material spray glue (cant remember the name or brand off the top of my head) the rest was put in with the bows and the little spring clamps http://www.ebay.ca/itm/Mopar-Headli..._Parts_Accessories&hash=item1e862af435&_uhb=1
lots of stretching and pulling to hook over the tabs around the windsheild and around the back window
http://www.moparmusclemagazine.com/howto/mopp_0210_how_to_replace_your_headliner_on_your_dodge_dart/
Love it!! Thanks guys have my plan in action!!
