7 1/4 behind 340
busboy
Will a 71/4 with a suregrip live behind a stock 340? Don't have the coin for the 83/4 right now. Street car only, and the rear is in it now.
I blew one to pieces behind a 318 years ago. I replaced it with another 7.25" I had laying around, and ran it behind the 318 for a couple of years, then about 16 years behind a hot 360. I pulled it out when I started the rebuild on the Valiant and I have an 8.75" to replace it. The biggest thing I found was to come off the line under steady throttle, and to not spin the tires around a corner. If you punch it hard off the line, or romp on it around a cormer, it WILL self destruct. Run it till it blows up, but start saving your pennies for either an 8.25" or 8.75".
I know they're weak. This one has the suregrip which I thought made it quite a bit stronger. I'm still collecting parts and saving my pennies for the 83/4.
Theres a reason ma mopar put 8 3/4's behind 340s!!!!!!!
You nailed it stroked340! A good way to tell what parts work well together is to look at what Chrysler grouped together. This goes for many things, such as torsion bars ,brake drums, radiator capacity, etc., not just differentials.
I just went through this. Had my car painted last summer, went from a 273 that had headers, hyd. cam, 4 bbl. ign. etc, pretty much everything you could just about do to a 273. I would guess it had around 210 HP or so. Ran like a dream with my 7 1/4 with 3.55 gears non-sure. I wanted to do at least one car show with it, had plans to upgrade to 8 3/4, but was dying to run it. I had a lot of people tell me that the 7 1/4 would handle 250 to 300 HP. So I put my 340 that is darn near stock 9:3:1 comp. or so, headers, 650 eddie carb,etc.all from my 273(except the carb) I did not go crazy, but did do a couple of straight burn outs amongst other things, and on the way home CLANG!! every so often. Opened it up, 11 teeth missing on the pass. side spider gear. It is a damn shame that these can't be built to with stand more. My was so light, I was able to chuck in the dumpster at work drums and all, all by my self. Now I have a 8 3/4 with 3.55 and it still runs great, but it is probably 100 lbs. heavier....This was just about 3 1/2 months ago..
Yes, the suregrip 7.25 is much stronger than an open 7.25. If you drive it knowing you can't be beating on it, it will last just fine. 318 A-bodies lasted for several 100,000 miles with 7.25's when not beaten on.
A lot of the '66 273 4bbl cars had 7¼s and automatics. Mine had over 300K when I sold it. From what I could tell, the fluid in it did not look too bad.
It will work. Just put a switch under your gas pedal that will activate a bomb in the likely event you floor it. This way, the rear end exploding won't be noticed.
This was what a trans shop told me when I took my 72 Dart (in 1976) with a 318/904 that was missing Drive 2. Of course, I changed drive 2 to rear end. I got the message and put in a 727.
On of them members has a sure grip 7 1/4 behind a 360 and it is doing ok. They fixed a lot of the problems with the sure grip model and they can take a lot more then a non sure grip 7 1/4. Just don't throw a set of slicks on her and you should be ok.
Like everyone else has stated you had better not beat on it. I just blew my 7 1/4 with my duster, and it only has a mildly built 318. Being young and dumb i couldn't keep my foot out of the loud pedal!
I'm running a fresh (with in the past 2 years) 360 with a cam, headers, and carb with a stock 7 1/4. Just listen to what people have to say, keep it cool off the line. I'm waiting for mine to go out so I can put the 8 1/4 in that I have in the garage.
