vwmoparguy
What typically fails when using a 7 1/4 rear end with a fairly stout small block on the street? I know it's not the desired rear end to use and all I hear is "don't use it". But.... why?
I see they make a new diff pin for it. Is this a problem area?
I was also wondering if a limited slip, trac lock,etc, diff from other vehicles (like a Jeep) will work in the Dodge 7 1/4 rear end? Some Jeeps use a Dana 35 which is a 7 1/4.
