7.25 Rear End Leaking?
jhdeval
Carrollton, GA
Okay so today I was changing the rear brakes and on the driver side I noticed some very heavy weight oil. I think I found it leaking behind the wheel hub that feeds into the rear end. Is that possible? If so what can I do to stop or fix it? I did check the oil level in the rear end and it was down.
Okay after I got the wheel on I noticed some play in the wheel. Could that be the seal still or is that something else?
