dart gt
i have a 70 340 stock block, j heads,268 comp cam,edelbrock performer intake with 800 thermo quad carb.Motor was rebuilt and have no more power than a 318.What could be the problem.Distributor was curbed,running no vacum,coil shows 9.95 volts at distributor.Timing is at 14 degrees,36 initial.It has a 4 speed and 323 gears.Any help would be greatly appreciated.Thanks David
