als499
Hi, I have a 1970 Plymouth Duster for sale. It has a '68 440 with forged crank, 12.5:1 pistons,1.6 Crane Gold Roller Rockers, Solid Lifter Cam, O-ringed 452 cast iron ported Heads with copper head gaskets,Weiand Tunnel Ram with twin Holley 660 center squirters,Enderle side mount linkage,MSD 7AL ignition,Moroso oil pan,electric fan and water pump,aluminum radiator,fenderwell 2" headers,custom 3.5" exhaust,727 transmission with reverse manual valvebody,4500 rpm stall converter,narrowed 8 3/4 rearend,aluminum tubs,ladder bar suspension with coil overs,front disc brakes. The body is very solid and in 2 stage primer.It has an 8 point roll cage and aftermarket gauges,fuel cell, a partially plumbed nitrous system,subframe connectors,manual steering,Weld Racing wheels,33x14x15 goodyear slicks,and more than I can think of at the moment.It has a clean CA title and can be registered for the street in CA,have not taken it to the track yet,Must Sell $7,500. Alan 530-934-7499 / 510-387-9467
