dustoff440
There are 4 bracket pieces on the saginaw pump p/s bracket on 70 and up
small block p/s set up. I have all but the one that is a perfect triangle with 1 hole near each corner. Would greatly appreciate any leads on getting this piece.
I can't see paying 75.00 to buy the whole kit to get one piece. If I had the tools I would fabricate it myself. I am going with this particular setup as I will be adding add on air at a later date. Thanks in advance.
picture is at http://roadtrip.yearone.com/2009/12/mopar-power-steering-conversion.html
scroll down to ps004(second pic of brackets) and see the almost perfectly triangular piece with 3 holes in it
