70 dart with 73 brakes issue
74demon
baltimore,md
So here my issue I have 70 swinger that I put brakes off of a 73 dart or so I was told (caliber are pin style) so I got my brake lines for a 73 and it is not going to work without being unsafe my line is 16 inch long and the one for a 70 is around 11 to 12 but I was wondering could I just swap my hangers over for a 70 style or do I need come up with a new plan ?
I have 73 brakes on a 71 demon..71 duster and 71 dart....I used the hose for a 73 Duster...
"Pin style?" A body brakes are not pin style. But if you WERE using 73/ later A body with calipers rear mounted, you need to use Volare hoses.
You might have Aspen? other? calipers
I would guess Volare brake hoses will fix you right up
Mine, 67 Dart, 73 / 74 A body rear mounted calipers and Volare hoses
attachment.php
If you're using Pin type calipers, you need to use 70-72 B/E body hoses.
