70 Duster points to 73 mopar electronic dist with HEI - getting parts
cawcislo
Ontario, Canada
I'd like to upgrade from points to Mopar electronic distibutor with HEI. I'm just gathering parts to make this happen, deisgned2drive.com adapter for distributor, late 70's mopar electronic distributor, low ohm e core coil (0.5 vs my stock mopar 1.5 ohm), HEI module. I think I can reuse my ignition wires, but I'll have to check to see what kind they are. One thing I want to source is the two prong pigtail (to plug into the factory mopar electornic distributor). Anyone have a part number for that. My coil wire is also a male.male version. Is there male/female coil wires so that the male end fits my female dist cap and the female end fits the new male e core coil.
Yes your old plug wires will work (if there are good ones). The two prong pigtail... I just cut it off and run the wires to the HEI module. You'll need to make them longer anyway. You can get a male/female wire end at any parts store.
