- Joined
- Mar 6, 2008
- Messages
- 1,131
- Reaction score
- 803
Bewy, that text refers to the maximum current allowed by the HEI module. It isn't necessarily the same as the current the coil would run if allowed to dwell until it reaches steady state. However, if the module and coil are designed to work together, this may be the saturation current. See here for what saturation current actual is though... It's not the same as peak DC current in a steady state. In fact, it's significantly less.
https://www.vishay.com/docs/48155/_did-you-know_ihlp_saturation_vmn-ms7373.pdf
Also, even in a situation where the coil is badly matched to the module and is dwelling for 10 milliseconds at a 600 RPM idle - that's 25 milliseconds between sparks on a V8 for a lot less current than what you would see with the dwell on a standard Mopar electronic ignition. It's still limiting the current and getting around the need for a ballast resistor.
