340plot
the bushy bush
hey guys. yes, i know i just got the car, but another car came up and i am going to get the other regardless, but do not need all these 340 cars!
this car is a wedge car, with the 340 callout on the hood, hood pins and black out treatment. however, there is no build sheet or fender tag to prove it.
the car is numbers matching. the engine is out and all done up with 202 j heads all new valves, springs. block is clean and line honed.
i do not have std pistons/rods for it.
i do not know if the trans is numbers correct.
has sharktooth grille, 340 un-silenced air cleaner, 8.75 with sure-grip 3:91, car has a cage, frame connectors. rallye dash in nice shape, but cut around radio a little. also have the front and rear seats. they are in nice shape with no rips other than the driver side headrest for the front bench.
car does need lowers, a spot 3x3 area in trunk has hole, fender are decent, doors are nice. door strikers have no broke metal. hood is straight but under side needs to be blasted.
tail panel has a dent, but otherwise pretty solid
this car is all there, but needs to be redone.
car is located 30 minutes from martinsville international speedway in va.
i will sell the car with or without the seats, as they are the main reason i bought the car! i need them for pinky.lol
will have the title in hand by febuary 1st. i was able to get the title, and i seen it, but it was still signed by last owner who never put it in his name, so i left it with him to do so.
this car is going up for best offer
if not sold by friday, it will no longer be for sale.
