71 dart 2 dr.
If you still have the car..I need the front shock towers and the inner fenders and where they mount to the firewall I'm trying to fix a butcher job on a former racecar.
I need the driver's side striker and about a 6" area around it. Is it still available?
I am in need of the torsion bar cross member and torsion bars if they are in good shape. The torsion bar cross member has to be cut from the floor and rockers just under the front seat and goes over the tail shaft of the tranny. If this is a part that you can cut out let me know how much you want and what the shipping might be to southeast mo. zip 63939. Thank you so much Kevin.
need left side front fender extension ... got one???????
looking for windsheild washer nozzles, and door jamb switch (3 prongs)
to area code j5c1e3 do ypu still have ?
Do you still have the car? If so, how much for the throttle cable sent to 42450? Thanks.
Do you happen to have the spare tire bracket and the two mounting tabs for the gas tank that hang down through the trunk floor?
Thanks
Gary
Also sending PM
