71Dartman440
Kansas440
Let's see if I can ask this so it makes sense
Does the main wire harness pass aft (towards rear of car) or forward (towards front of car) of the steering column mounting brace.
If it's aft of the bracket it appears the harnesses whole right side (from steering column to passenger door) would have to be carefully fed through this area.
Or if it's forward of the bracket it appears to bypass this area fairly easily but the steering column mounting brace has some fairly sharp edges to it that could wear on the harness over time.
In picture you can see I've routed the main harness forward of the bracket...thoughts?
Thanks
Thanks
