bridge16354
71 dodge dart swinger,easy project,super clean new mexico car,absolutely no rust,just some minor dents,just needs the lower piece cut from a donor core support and welded in.was medium green metalic,now in primer,perfect white vinyl roof.tinted glass. 6cyl. column shift automatic.drivetrain gone.power steering,power disc brakes.green interior complete,needs seat covers and carpet,dash cracked.PST sway bar,BBP power disc brakes with 11 3/4 rotors,tubular upper control arms. mosier 8 3/4 742 4.56 sure grip bbp axles 11"rear brakes.extra leaf springs. new clutch pack in sure grip.340 torsion bars with new boots .built 360 and 727,rebuilt with shiftkit reman.stock converter. built 360,.30 over TRW 9 1/2:1 pistons,floating pins,AAARP rod bolts,windage tray,j headsported and polished,gasket matched, 2.02 stainless steel valves,hardened exhaust seats,triple valve springs. comp cams .501 .292,rhoades lifters,double roller timing components.recurved electronic distributor with MP chrome box.high torque lightweight starter. 73-76 k frame.schumaker motor mounts. stock spreadbore intake with rebuilt thermoquad,MP unsilenced air cleaner with 360 magnum pie tin.standard crankshaft.hedman headers.aluminun radiator.KYB gas adjust shocks,car is pretty much complete,just needs battery cables,radiator hoses,some screws and trim clips. clear pa title.located in northwest pa.1/2 hour from i-79. 6,000 or trade for b-body or 67-74 baracuda or challenger,4500. as a roller.working on pics.
