71 Scamp Upgrade
LemonTwistScamp
New Member
Hey All!
Bought a nice Scamp (6 cyl) to work on with my son. I know you've probably had these questions before but... I heard I need to do the following changes but I need more help / details.
1) Change the front spindles to 73 up a/body. (for the brakes)
2) Change the torsion bar.
3) Change the rear end to get the larger bolt pattern
2 questions.
1) 1 & 2 above SOUND simple, but theres more to it. Any help would be appreciated.
2) I know the axel swap is going to take some welding etc. Are there just different axels to swap for the larger bolt pattern?
Thanks,
Perk
Good luck on the spindles, the B-body guys are snarfin' them up, unless you go aftermarket. As far as the rear end, There are a body 8.75's out there, but until I built one I could have added a couple of bucks and ordered a drop in Moser 60. Could also look for an 8.25.
