Butch67
Hey all,
I have been looking for a A833 for a while, but no rush since the rest of the car was still in the building stage. Now the motor is done and the car is coming along nicely but guess what no transmission yet.
The problem is I found a 72 A833 that needed to be rebuilt or reconditioned. I took it home cleaned the crap off of it and started the disassemble. It came apart rather nicely and the casing appears to be in very good condition. So on to the rebuild stage.
I took all the components down to the local mopar guru and he started going over everything. He suggested replacing many parts but the main problem is both the input shaft and the output shaft have some really big wear marks on them where the needle bearings sit.
Trying to find these shafts has been terrible. I guess they were not many made? It has a 25 tooth gear count that makes it hard to find. He was just at Carylye last weekend and couldn't find either of them. Then he talked to the guys at Brewers and they said they have not been re-manufactured either yet.
Any help would be great.
I am not sure If it would be cheaper to change it over to the older 66-71 style? That would mean changing everything.
Bite the bullet and buy the one I did find, really expensive!!!
Or just move on and buy a different rebuilt one and check it out anyway.
Thanks Butch
:burnout:
Thanks Butch
:burnout:
