[SOLD] 72 dart swinger
JR dart swinger
New Member
PERRY FL 32348
Rating - 0%
0   0   0
1972 dodge dart swinger project..all parts are inside the car have title..no time for it..had 440/727 in it when I got it never was finished..man started it but he kept the motor for his duster l. I bought the roller for $3500....selling it for $1000 o.b.o..location is perry fl...had metal finish work done no bondo...thats body icing over raw metal..has some rust now from setting does have duraglass work around back window..i have a 1972 440/727 combo out of a winnebago that ill sell with it need to be freshened up.. $500... sorry I added the attached picture of the spot filler icing because some people might not know what that is and think there is bondo all over the car. The man i got it from was a body man and showed me it wasn't bondo it sands off very easy by hand with 400gr..and it was to protect the bare spots as he was working on it after work a little at a time...sorry if any misunderstandings
Explain: "Body Icing" over raw metal???... that's a new one... never heard that term. Even though you said no Bondo...it sure looks like Bondo spread out all over the car to me, in those pictures.
It's glazing &finish filler called icing...there is raw metal under it you can sand it off with 400g paper by hand..
it was to protect the metal work till the car was sanded or blasted for primer...because only the small spot we're worked a little bit at a time by a body guy I got the car from...I said the same thing till he showed me..
