doinintheduster
Member
- Joined
- May 1, 2010
- Messages
- 11
- Reaction score
- 0
Help! i finally have a window but want to be sure i put it in right... it was busted out so im not sure how it mounted or if i still have all the hardware. i have four plastic bushing looking pieces and two up stops. an aluminum bracket with a nylon roller. did 72 dusters need anything else? i posted what i think i need under parts wanted but i don't understand how the screws and studded pieces both fit through the hole. here is a picture i found of a 71 but 72 seems to be an odd ball year. just wanna be sure.
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=6631630&Main=6631237
i have screws through my plastic bushings and don't remember ever pulling the studded pieces out of the pile of glass in the bottom of the door. a friend already suggested looking at drivers side, but i don't think its ever been apart and i don't want to be the first to pull it apart. my soul screamed when i had to pull the plastic off the passenger side. any input would be much appreciated.
