72 Duster What Max Cragar SS Rims And Tires Front And Rear Sizes Needed
Andrew T Lombardo
Active Member
Bronx, New York
Hi Everyone, I have a 1972 Duster 340 H Code and would like to put Cragar's SS rims on it along with Tires. My question is, what size Cragar rims for the front and for the rear along with the max size tire sizes needed for front and rear without any rubbing? The suspension is all stock front with a 8 3/4 stock rear. Thanks
Well i have a 205 /70/15 up front and then set the ride height up as it rubbed on the pass side with someone in the car otherwise it was fine alone. Not sure if a 215/70/15 would clear? Thank you for the compliment.
Not sure only rubbed when i made a right hand turn with a passenger. They are cooper passenger car tires. Lifeliner i think
I had 215/75r14 on front and they did not rub anything on 73 duster.i installed 185/70r14 on it for now.i. believe they are stock wheels.
