72 Swinger quarter panel replacement
InTheDart
Member
What model years could serve as a donor for a rear quarter panel for my 1972 Swinger? I'm probably going to bite the bullet and go with an AMD product but thought I would throw this question out there.
Thanks for any comments!
I believe 70 - 73 had the rear valance under the rear bumper, and 74 - up did not, hope this helps:cheers:
I think they were the same from 70-76 but the side marker changed in 73 and up.
70-71 are the same but have different marker light then you have now.
72-73 are the same as what you have now.
if you only need sections that do not include the marker lights ir very back of the car you can use 67-up pieces
Thanks to all of you who replied. I have a solid 74 Swinger that could serve as the donor, but not sure if I want to cut that out if I would have to rework the side marker position. Live and learn!
