[SOLD] 727/904/833 speedometer pinions/parts
Locomotion
Florida
* 28, 29 tooth gears - $15.00
* 30, 34 tooth gears - $20.00
* 26-45 tooth housings - $15.00
* Speedometer housing clamp/bolt set - $5.00
All prices are per item and include shipping within the 48 states from Florida - 32117.
(Sorry, I don't do paypal.)
Another question for you, do you have the 2 brackets that go from the 904 trans to the side of the motor block. ( I have a 904 with a small block in a A-Body ). Thanks Webby.
Webby,
I have these. The top one is 6 cyl. only.
The middle 2 are for one side and I'm pretty sure the bottom one is for the other side. It has a small crack at the right end.
I think 904 and 727 are the same, but not 100% sure. I just never used them on my race cars. If you can confirm these are what you need, PM me.
I need to fill in some blanks in my knowledge.
These gears correlate to a specific rear axle ratio correct?
Is there a list or graph of what gears apply to what rear axle ratios?
Would someone enlighten me? -Thank you very much.
