toddlaine
The 72 Dart I just got has w/318 and a 727. When I changed the exhaust from the glass packs the previous owner had I now can hear this problem. In Drive it's fine, but when you go to R,N,D,2,1 there is a clicking coming from the trans. When you rev in N it gets faster. The guy does not have any kickdown cable installed and said he's been manually shifting 1,2,D. It is a Holley 2 Barrel R8448 carb installed. He has a stock throttle cable and a lokar kickdown cable not installed to carb yet. Sould I try to use this cable or Get the BPE cable and should this fix this noise. I am not driving the car intill this is fixed don't want to hurt anything more than it is. Checked fluid level and added a pint to trans. Any info will help.
