727 in 72 Duster
hillsidehemi
Member
I have a 72 Slant 6 Duster that I'm using the conversion mounts to put in a LA 360 with a 727 trans. Does the 727 fit the trans tunnel? Will the slant trans crossmember/mount be usuable? If not is there a crossmember that will work or am just fabbing up something?
thanks
yes,,,,the 727 came behind the 340s in 72 duster...
you can use your cross member
