727 line pressure > 1300 H.P.
sorry, pulled the 727 years ago and installed a glide. I will never use a 727 again.
i don't know what it is but there is a turbo action "cheetah" valve body in my 727, what ever that pressure is.
same one I have in my 904. I don't know if you can turn up the wick or not as that would be a cheap way to ensure you have more holding power.
528 Indy aluminum, 12 1/2 to 1 , roller cam and rockers, 1050 dominator, extensive port work and 400 fogger.
what rpm you looking to turn? we built a nice 528 that made 773hp at 6600, but we were running a mag crossram and just some smoothing on the Stage V heads.
You need 200 lbs in low gear.
we ran that in a friends 8.87 N/A 440-1 combo, but it was only a bit over 900hp. That was a fully rollerized Lofgren trans utilizing a TranzAct brake non LBA. 14x32 slick and would launch like a rocket. 2600lb weight.
couldn't be a red coronet would it? and being an Az guy you have me curious as to who you are!
