Header diameter and collector suggestions
I run a 1 7/8 tube on my 374 and i think they work great! i do have the Pipe Max program, but i did have it when i put my headers on.
i walked over and talked to you a few times. i was wearing a Reid Holland Motorsports crew shirt.
Small world, I remember you now. You may have helped us get the car in the ramp too. That was a great divisional, I realized there is a lot to learn. Broke the cylinder out of No. 6 on the last pass. I'm going to put a 340 in the car and finish the summer then build the headers for the 414.
For what it's worth (not much) I had 2" headers on a roller motor 406. Car wasn't particularly fast, but I don't think the too-big headers slowed it down much, if at all. (2" into 3 1/2 collector, about 25" primary if I remember right, custom under chassis, never run without a 3 1/2 muffler system.
That was a great divisional. Broke the cylinder out of No. 6 on the last pass. I'm going to put a 340 in the car and finish the summer then build the headers for the 414.
If you were running La head configuration, who made the flanges? Or did you construct some adapter plates like a Chevrolet sprint car header, opening up the bolt pattern for 2" primary.
I made some adapter plates with an included angle (10 degrees? Don't recall esactly) and used the Stahl Chevy pattern flanges.
I wouldn't do it again, I think it might have run harder, (maybe a little, not much) with a 1 7/8 header. I have 2" hookers and 2"custom on my big block cars. (I have a ridiculously large big block mopar set, custom built, for an A-body big block too. 2 1/4 x 4 x 34? Semi-fenderwell)
They might work great on a 572.
Nice daytona! I'd guess you're going to want to be in the 28-32" range with a 3" collector but a 3.5" merge will work But again, that's a GUESS! Get pipemax and enter your info and let that spec your combo. I always try to build a header 'in the middle' of what I have meaning, they'd work decent on both more and less power combos. Try to use gentle radius and avoid S bends. Try to get them close but, I wouldn't sweat different lengths. Locate the primary in the collectors respective of the firing order. I use vacuum cleaner hose to conceptualize the design.
Thanks for the information. Stahl's pricing seems reasonable. I will reach out to them on Monday.
