727 Pressure port
chargd72
austin
I'm trying to route cooler lines from my tranny to the radiator. Is there a port on the passenger side of a 727 I can use? There is a line pressure port between the front and rear servo but not sure if that's an ideal location. ?? The typical pressure port in front of the shift lever is cluttered with TTI headers and after market shifter cable.
You can't use a pressure test port for a cooler line without loosing the pressure to parts than need it.
Just get in there and deal with it like the rest of us had to do. :D
Well, damn. Ok.
I know.:D
I swapped mine over to 3/8 lines and all larger fittings with the cable bracket and headers in the way.
Taking the bracket off on my car makes me readjust sometimes 3-4 times before it's back right where I want it.
I'm putting in steel braided lines but made the mistake of putting in 8 AN instead of 6 AN trying to get more volume in there.
Unless you drilled out the case and retapped it to use larger fittings you won't get any more flow because the port hole size in the case isn't nearly big enough to take advantage of the -8 line size
