73-76 front "beak"
^ I agree, This looks like a 73-74 dart. Changed styles in 1975. 75-76 are the same.
how is the 73-4 beak different from the 75-6 ?
It's not! The only difference was the chrome trim used on it. The '73-'74 has a plain chrome trim strip across the front while '75-'76 had a taller version with DODGE stamped in it.
Damn yall boogered up dude's for sale ad with some bullshit that wasn't even right.
And the brackets that the grille screws to. Park light area is more recessed on 75-76, therefore brackets are farther back. You can put a 73-74 grille in a 75-76 header and just not use all the screws, but to put a 75-76 grille in a 73-74 header, you need to cut the brackets off the header panel and still not use all the screws.
Do you have better pictures so the people can see the front of it(emblem)? Also any pics of the underside(to check for rust)
