Baghdad Dart
- Joined
- Oct 29, 2008
- Messages
- 96
- Reaction score
- 0
We are putting a manual gear box from a B body into a 74 Duster. Problem is that the pitman arm off the power steering box wont fit the splines on the manual box. Its too big, the arm just spins on the shaft. I am told that the arm that we need is from 73 - 76 A body. The early ones dont work at all, the taper on the joint is from the bottom and the taper on the steering arm is from the top..they dont match...what to do??? Where to buy the correct one?? Is the manual pitman arom from the same years...73 - 76 .. the smaller size same as the B body gear box????? Gues thats the biggest question..
Jeff
Jeff
