73Charger318
Member Rt 66 Mopar Club
So I've read some old posts on this and still a bit confused as to the best way to do this.
1. The fuel tank line will stay connected to the 1/4 inch metal line coming up from gas tank.
2. The purge line can run to the drivers side manifold vacuum or i guess to any manifold vacuum source. I'll be using the left side ported vacuum for the distributor.
3. Most confusing is the carb bowl line since the 1406 doesn't have a connection for it. Just cap it off?
Any comments and suggestions greatly appreciated!
