73 Dart Leaf Springs
Johnjgonzo8D
So-Cal (OC)
Hey fellas;
So I installed new leaf springs that give my 73 Dart Swinger that Stink Bug look, it's about 2.5 Inches higher in the back. My only problem is that when the car is going over a bump, on the way down the bump, there is a loud banging sound. I am thinking it is the leaf springs returning to their original position before going over the bump and springing back. Would I need new shackles? Should I do away with the shackles completely? I don't exactly know how I should fix this issue, so any guidance in the right direction would help. Thanks in advance.
Hey fellas;
Are your shocks long enough? They could be going to full travel and banging. -Jed.
I would get the right length shocks IF that is the case.
Shocks should never "bang" out to full extension anyway if they are any good.
I'm confused . You said you installed new springs and you asked if you need new shackles . Why didn't you not install new shackle bushings and new shocks at the same time ? Also, when installing new springs , did you leave the bushing bolts loose until the car is on the tires to prevent binding ? I'm thinking you have a binding situation . Just a thought .
