73 Dart Swinger Alignment
Lazares81
"Mopar: You're either with us, or behind us!"
Los Angeles
Hey everyone! I am new to this site, but hopefully I can learn a lot here.
I just purchased this dart about 2 months ago, it sat in the front of my house for about 2 weeks before I began playing around with it. From the moment I bought it, the car pulled to the right extremely hard, you let go of the wheel and change 3 lanes in the blink of an eye. I did the alignment setting the camber and toe to dead zeros( my machine doesnt go back to this year, and i didnt have the specs available at the time). Then right after i did this the steering wheel began to stick when I would try to make a turn more than 360 degrees on the wheel. When i say stick i mean it felt like the steering wheel locked momentarily while i have to force it loose again. And the car is still pulling hard, except now the pull changes from left to right depending on which way the steering wheel sticks that day before i force it loose. I tried rotating tires and redoing alignment and reset it to dead zeros again, although this second time it was only out .10 overall in the front.
Any help would be greatly appreciated :-) thank you
..................OK try this......adj the front upper control arm bolt so u push the arm all the way out..........adj rear bolt so c a is all the way in.......see what u got.......u want all the + caster u can get.........adj till u get -.5 camber ........kim........
thank you i will try resetting the camber, and report feedback. Thank you for the advice
