Does 73 Dart sport dash frame will work with no problem on 72 duster?
Thanks on advance
Thanks on advance
The heater control tabs are way different. You would either need to use the 73 to 76 controller or modify the tabs. Other than that, they are the same.Does 73 Dart sport dash frame will work with no problem on 72 duster?
Thanks on advance
only 73 will work from 73-76 with no problem?The heater control tabs are way different. You would either need to use the 73 to 76 controller or modify the tabs. Other than that, they are the same.
