Stacked360
- Joined
- Mar 9, 2009
- Messages
- 195
- Reaction score
- 4
My 8 3/4 has 2.73 gear set no locker and small bolt pattern axles, it is a 489 housing, but other than that no redeeming features. I measured from wheel mounting flange to mounting flange and got almost exactly 54". So I am on the search for other rear ends that will work in its stead, was considering a modern set up with independent suspension but most that are hefty enough to take a 5.7 Hemi are much larger than 54". Does anyone know the dimensions for perhaps B-body axles? or any other ideas from anyone that has done some rear end swaps in their a-body. I always get a bit lost when figuring this out because of how the a-body rear end was a bit to narrow for the car to begin with, and with the right size rearend I can achieve the 8" wide tire and the right "look" where the tires fill the wheel wells without the rubs\\
