73 Duster
Howard1784
Rochester, NY
73 Duster
Originally, this car had a 318 which was replaced by 360 motor I bought which is now my spare. The rear and transmission went on me and I had then re done at the same time. I did not have indoor storage and paint job went bad in the sun from being baked. All the work has been professionally done. The interior is nice with no rips or tears in the seats. When I bough the car in 2006, the odometer read 35,000 mi, now there is 38,000 mi. I believe this to be the original mileage, but can’t confirm this.
The motor is now a true Mopar Magnum 360/380 HP crate motor from Chrysler. Less than 50 mi on this new motor!
Part # # P5249499
The Magnum 380 crate motor head is a swirl port design that has smaller combustion chambers and a higher compression ratio (nominal 9.0:1). Different intake and exhaust port sizing flows more air without modifications to the cylinder heads. Breathing is enhanced with 1.925" intake valves and 1.625" exhaust valves. Overall package of smaller valves and better ports flow more air. Next, we slide in our .501" / .513" lift, 288/292 degree duration hydraulic roller camshaft, add a 4BBL carbureted M1® single plane intake manifold . We add special valve springs and a double roller timing chain as well as an MPP electronic distributor. The distinctive Mopar cast valve covers with 10 screws are added to the package, with an oil pan (center sump) similar to the Commando engines. It is recommended you add your own 750 cfm Holley carburetor and headers to complete the package. Dyno testing with a 750 cfm carburetor and 17/8" headers show horsepower output to be 380+ at 5300 RPM. Torque output is 410+ lb/ft at 4400 RPM, with over 350 lb/ft available from 2000 to 5700 RPM.
MSD 6A Ignition
New Mopar electronic ignition
New TTI Headers, exhaust cut outs
Ford 9 inch rear with 3.73 gears and posi traction
Custom Frame connectors
Just Suspension Kit front end replacement
Be Cool radiator with a custom radiator shroud with dual electric fans 190 on 170 off (4500 cfm pulling force) (switch mounted in upper hose for accurate reading)
Excellent tires
Brakes are good in front and rear
Transmission rebuilt @3K miles ago with “hard parts” and a cooler was added
New 3600 Stall convertor from Trans Specialties (installed same time as motor)
125 shot NOS (Never used)
Holley 750 dbl. pumper
B&M reverse manual shifter
Dynomax mufflers
Custom H pipe
2.5 inch exhaust cutouts
All brake lines replaced except combo valve to axle
New Powermaster alternator
Power steering/ Power brakes
Autometer tach, oil and water temp gauges
The frame is solid
Wiring harness parts replaced: engine, alternator and new firewall junction block with 3 new connectors
ABS plastic headliner
Package tray
Pulleys powder coated
New power steering pulley and adapter kit from Bouchillon Performance
Dash was blasted, painted matte black, speedo cluster restored, new dash pad
Radio delete cluster not included
The interior was removed and the cowl, firewall and floor pans were wire brushed and cleaned. Next, POR 15 was applied to the same areas. Finally, I put Eastwood sound deadener in all of those areas to include the package tray area.
Extra parts: 2 doors, spare mild 360 motor with 3K miles on it, trim pieces, wiper motor, new carpet, Duster floor mats, electric retractable radio antennae, J 360 heads.
The bad:
Needs paint
¼ quarter panel is bubbling (I have new one)
Dents and dings throughout car
New windshield to be installed next week as I had to remove it and POR 15 the channel after wire brushing it to bare metal. (This was done to remove dash)
Headlights inop, currently working on locating the probolem
Spare 360 information:
71-74 Dodge 360 ci
Cylinder head casting# 974 68cc combustion chamber 1.881" intake valves 1.600" exhaust valves
Pistons- Silvolite part# 1279-.040 cast with .050" dish
Final compression ratio- 8.4:1
Crankshaft ground .010" under on both rods and mains
Competition Cams cam&lifter kit part# CL20-224-4
.488" intake lift .491" exhaust lift
274' intake duration (230' duration @.050"lift), 286' exhaust duration (236' duration @ .050" lift)
More pics forthcoming and I have not decided on a firm price, but would take reasonble offers. PM any further information.
The r/f floor pan is showing some rust and small holes, but I have another new pan in waiting. These pics are before I put the driver's seat in and I have yet to put in the back seats/belts etc. which only takes 15 minutes or so. I am 50/50 on getting a new seat divider and laying sound deadener over it. I also have new carpet ready to go in.
Dash and steering column is in. I will be putting in the rear seats etc later. I am keeping the r/f seat out until I decide on the floor pan. Current pics are forthcoming.
