[SOLD] 73 model 340 engine
superbyrd
henderson,ky
here is a 1973 model (5-31-72 casting#) 340 engine. complete except intake, carb, distributor, exh.manifolds. standard bore, standard crank, has "J" 2.02/1.60 valve "915",casting heads. good clean engine. look at the pics, they show casting numbers, VIN, and front stampings. has valve covers, timing cover, oil pan and windage tray. $1400. PM here. thanks.
those in the pic are all i can make out. the stamping is really light on a couple. not trying to make them worse
