Stoney Anderson
Member
If nothing powers on with the key in run where do I go from there? The ballast resistor does not get warm at all. Headlights work but no turn signals no brake lights no dash lights no radio that is tapped into one of the sources from the fuse box.Don't work yourself into confusion. Think about what is common. If the headlights work, you are getting battery power through the bulkhead, through the ammeter, and into the passenger compartment. If anything works in the key "accessory" position, the key switch is at least "receiving" power from the ammeter circuit/ bulkhead.
Does anything work with key "in run"? Gauges? warning lights on the cluster? If so, power is at least getting that far. Next see if power is making it out through the bulkhead to the ballast resistor. That wire splits and feeds the blue wire going to the alternator field (There are two, green and blue)
No warning lights. Like my second brake or e brake and no oil pressure warning light like before
The key is really hard to put in and take out but I can’t imagine that has anything to do it it
