74 Dodge Dart turn signal indicator
Discussion in 'Electrical and Ignition' started by Benjamin Thomas Powell, May 10, 2018.
  1. Benjamin Thomas Powell
    Benjamin Thomas Powell Member
    17
    1
    May 8, 2018
    Elmer, NJ
    Local Time:
    1:55 PM
    So I’ve been working on A 1974 Dodge Dart and I hit a little stumble. Currently my left turn signal indicator work on the gauge cluster but the right side does not. I replaced the fuse to the lights and recently bought a new turn signal assembly do I know the problem isn’t in the column. I also replaced and tested all of the lights before re-installing it. All the exterior lights work, just not the indicator light. Is there something I’m missing?
  2. TrailBeast
    TrailBeast Slightly Twisted Member
    19,072
    5321
    Mar 11, 2011
    Arizona
    View My Photos
    Local Time:
    11:55 AM
    Check it at the round wire socket on the back of the cluster, as it could be just a lost connection to the pin on the back of the cluster.
  3. Benjamin Thomas Powell
    17
    1
    May 8, 2018
    Elmer, NJ
    Local Time:
    1:55 PM
    I will, where is the wire for the turn signal light coming from? I wasn’t able to trace it on the diagram at my Mopar.com
  4. TrailBeast
    19,072
    5321
    Mar 11, 2011
    Arizona
    View My Photos
    Local Time:
    11:55 AM
    It comes from the same wires that power your signals, but I don't know where specifically.
    I can tell you that on that plug they are right next to each other.
  5. Benjamin Thomas Powell
    17
    1
    May 8, 2018
    Elmer, NJ
    Local Time:
    1:55 PM
    Alright, I’ll try to track it down. The pins and sockets look good
  6. TrailBeast
    19,072
    5321
    Mar 11, 2011
    Arizona
    View My Photos
    Local Time:
    11:55 AM
    Try a test light on the signals pins and see if you have power to it there.
  7. halifaxhops
    halifaxhops It's going to get stupid around here! FABO Gold Member
    47,020
    15197
    Jan 20, 2014
    CENTRURAL, PA
    View My Photos
    Local Time:
    1:55 PM
    Clean it all with a pencil eraser and then wipe it down.
  8. Benjamin Thomas Powell
    17
    1
    May 8, 2018
    Elmer, NJ
    Local Time:
    1:55 PM
    The board isn’t the problem. I cleaned that up with a brass wire wheel
  9. Benjamin Thomas Powell
    17
    1
    May 8, 2018
    Elmer, NJ
    Local Time:
    1:55 PM
    I could but I’m not sure what goes where so I don’t want to ground a power feed
  10. TrailBeast
    19,072
    5321
    Mar 11, 2011
    Arizona
    View My Photos
    Local Time:
    11:55 AM
    Grounding a power feed momentarily can only result in making your test light light up.
    Turn on the signal that the indicator works and then find the pin that makes your test light flash.
    Then turn the other signal on and test the pins on both sides of the one that flashed.
    One of those should also make the test light flash.
    If it doesn't then the problem is not in the cluster, but in the feed to it from the signal wiring.
  11. Benjamin Thomas Powell
    17
    1
    May 8, 2018
    Elmer, NJ
    Local Time:
    1:55 PM
    Randomly started to work when I started testing lights. It must have just been a poor connection somewhere
  12. TrailBeast
    19,072
    5321
    Mar 11, 2011
    Arizona
    View My Photos
    Local Time:
    11:55 AM
    The gas gauge on the Wife's 72 Dart did that same thing basically and when I wiggled the round connector on the back of the cluster it started working again.
    I am a firm believer in starting wit the easy solutions first.:D
  13. Benjamin Thomas Powell
    17
    1
    May 8, 2018
    Elmer, NJ
    Local Time:
    1:55 PM
    Hey if it works, it works Thankyou for helping
  14. 67Dart273
    67Dart273 Well-Known Member
    38,303
    5882
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    10:55 AM
    You need to buy yourself a copy of the factory service manual. The 74 is not available for free download that I know of. The 73 is over at MyMopar but the wiring is somewhat different. TS wiring, however should be same
    The conductors for the dash indicators come right off the connector for the TS switch. Left and right front should each have two wires right at the connector, one going to firewall and one going to the dash cluster
    EDIT actually the dash indicator branches ARE "sorta" shown. They are showing the light green branching off at the bulkhead, and the tan branching off at the TS switch connector, LMAO. I'm sure they connect at the same location, instead.
    So Light Green comes in the page, goes all the way up the page to pin 6 of the cluster connector
    Tan, LMFAO........comes off the TS switch, goes off the page to the other page, UP THAT PAGE a bit, then goes BACK onto the original page LOL, and on up the page to pin 7 of the cluster connector.
  15. Benjamin Thomas Powell
    17
    1
    May 8, 2018
    Elmer, NJ
    Local Time:
    1:55 PM
    I’ve been using the one on myMopar but have noticed the slight differences. I guess I can’t avoid the inevitable of shelling out the 8 dollars lol
