74 duster 3 speed manual problems
History?
Troubles in the past?
Always shifted "great?"
Always shifted "maybe?"
Lots of wiggle room here. Floor shift? Column?
If column, there's lots of pitfalls there including the reverse / column lockout
History?
does it feel like its stuck in the neutral position ??
It worked fine then car would not go in gear my big question is how hard is it to find parts it needed.
A bigger question is what do you have?
Kind of an information in=information out type thing. :D
Yea, the levers do not always return to there neutral position. Go under and straighten them out. That maybe the issue. After that, IDK.
Is there anywhere that I could get parts for it ? It is a slant6 with column shift and right now it is stuck in first gear.
Does anyone know how to adjust the linkage the car goes into first gear and neutral but not into second, third and reverse or anyone have a diagram of the linkage?
