Thanks for all the positive comments guys!
Here is a brake down on the car:
74 duster 6cyl auto purchased from David Freiburger(CA)via e-bay and shipped to Indiana
Interior changed from green to black bench.Heater and radio delete.
73 340 dart sport front supsension w/manual disc brakes,steering, and sway bar
8 1/4 rear with 3.55 sure grip
74 360 from a real 360 duster with 63k miles,valve job and guides on the heads,shortblock untouched (110 psi cranking compression)
74 727 with stock rebuild,column shift
Brake torque at 1200 RPM on the line,shift at approx 4500 and cross the line at 4500.I made 20 passes in two days.
