edwinator13
Active Member
Does anyone know which one is the Ignition Switch wire and the starter wire inside the car? Trying to install an alarm and it requires connection to these wires.
This helps a lot. I really appreciate your help.Standby.....................EDIT these are difficult for me to deal with because it is a big folder with individual jpg files. Here is the column switch connector J2A12DBL is what you want. J2A is the circuit, 12 is the wire size, and Dark BLue is the wire color
For starter you want S2 12Y second from top
Also DID YOU BYPASS your seat belt interlock relay? This is the relay under the hood with the push button reset. There will be two fairly large yellow-ish wires in that connector. Wire them permanently together
