You'll find a white plastic harness connector in the engine harness. The differences are in wire lengths and routing away from that connector to senders, alternator, etc..
I suggest you delete that connector if you can. melting and shorts were somewhat common there. It was only added for ease of assembly anyway. Earlier models had no such connector. Their engine harnesses were different from bulkhead connector onward.
