does anyone have a service manual for a 75 dart that they could scan and send me a few pages of? i need the pages for changing the heater core with a/c.
Jus so you guys know, "that manual" came from HERE involving several of us. One member sent me the files, and another member put up a place to host it and got me stepped through doing so. There may be some differences from 73-4-5, but most the mechanicals would be close or the same. Might be some electrical differences.
I don't know what you did wrong, that file works OK. Did you actually download the file? Do you have a .pdf reader (such as Acrobat) installed? Right click the file and see what it says under "properties." The chassis manual should be about 198.5 Mb
i finally got it to work, if i downloaded the .zip file it wouldnt let me open it, but if i opened the manual on the site, then saved it, it worked fine. Also got the heater core switched out, way easier than i was making it. Thanks for the help.
