750 cfm vac sec carb!
Curious if it's a good carb, why you getting rid of it? I'm interested, however my 360 IS stock...was going to try the 600cfm version, but this is a good deal. Worried it's going to be too big however!
You can buy a spring kit(different colors)for the vacuum sec. carbs.These help with when the secondaries will open.Should be more than enough for a stockish 360.
Well to answer your question I'm selling it because my new motor needs more then this Carb.. my new 360 is .30 over 10.2:1,max ported x heads, 580 solid cam,port matched m1 intake. And I don't want vac secondarys I will be doing more racing.. but it is a nice carb
