moparblood
parting out dart!
Complete air cleaner to driveshaft
has alum intake/2.5 exhaust manifold
aluminum OD 4 speed trans New clutch
1500. local pickup only
Doors w/glass -125. each
driver fender -100.
clutch pedals- 150.
large bolt pat Disc brake set up -300.
rear wind shield - 100.
rear side glass-35.
steering column w/key-250.
rear bumper assembly w/aluminum inserts brackets -350.
front bench seat- 75.
rear seat - 75.
rear 7 1/4 axle -100.
manual steering box-100.
floor tunnel-100.
4 speed adjuster kit
z bar
shaft rod/boot
fork
ball stud bracket
frame ball stud
reverse light- 200.
tail light panel- 150.
any other parts you can inquire about!
driver fender -100.
clutch pedals- 150.
rear side glass-35.
rear seat - 75.
floor tunnel-100.
z bar
shaft rod/boot
fork
ball stud bracket
frame ball stud
reverse light- 200.
