1wild&crazyguy
Banned
This is exactly what I have. Stock late '70's pistons (flat top), 0.060" down the hole, etc. There won't be ideal quench, but if you've ever taken the heads off a stock magnum 360 (I have), you'll find the pistons are still down the hole about .040 and are dished. They also run a 0.054" head gasket and I run LA head gaskets which are 0.041". What he would end up with would be within the factory tolerances for a stock 93+ 360 magnum. If the LA heads were better they would have kept them.
.060?
I've taken 3 sets off due to cracking into the exhaust ports from & just off the seats
You're forgetting the magnum motor was not pushing any compression/octane boundrys or anywhere near the limits of pump octane, so just because they had the closed chamber does not mean it did anything when it came to octane vs actual comp ratio, the cylinder pressure was weak , as in 'stock' like 135-140 maybe dynamic/cranking.
I really like the idea of a dish and closed chamber, but in that example it's yielding squat for new found hp cause the quench & compression is not there.
They made the switch in heads to save money and more easily meet emission standards, the mags are a thinner casting closed chamber head, the rockers require less material/money to produce, the also used the 1.6 with a roller on top of that so they could lift the valve very lil yet a lot faster to make up for the lift loss/lil dur, they also run them 200 or so to keep them hot for emissions, too bad they didn't consider this when deciding on using a thin casting head.
Performance was not really in the design of magnum heads 1st and foremost.
I've also been running 16 degrees of timing up front and 36 total (in at 2200rpm) with a 4-speed on 89 with no pinging.
I run 87 octane with a ported x head 340 w/ kb243 flat tops, that come out of the hole .019 w/4spd 26* intitial/34*total.
I have a 410 stroker that has 10.1 comp, ported open chamber J heads w/11/32 stem 2.02/1.60 with quench dome hypers set at .038 q dist cranking 175psi w/89 octane, haven't tried 87 yet.
if you keep the cranking psi to around 175, you can use open chamber heads all day long...now if you do some prep work 'like correcting the chambers to the bore size being used, polish the chamber a lil, you can go higher.
If you're buying an intake anyway, the mag intake is hardly different in price. Junkyard the heads and rockers, and head bolts, buy some 7.650" pushrods and you're ready to go. "LA" valve covers bolt right on.
That must be based on a rebuilt set of magnum, cause wrecking yard magnums at this point, unless redone, will be worn out and junk, and the springs are beehive and WAY to weak for anything beyond a stock magnum cam.
The average set of LA heads are in need of a valve job, and have all the same spring limitations as the magnum heads. Most people also aren't going to spend the money to get serious head milling done (would make up the price difference for the magnum parts), and then you still end up with an open chamber turd anyway. Magnum heads start at 10cc smaller than LA heads to begin with.
What do you mean by spring limitations, cause they use 2 diff styles of springs to start, and the LA head will work with 'no magic' in the 1.65-1.75 inst height range all day, mine are set a 1.80 for instance.
all heads are gonna require the spring seats to be machined for inners if a double is gonna be used, and guide to retainer/cut to .500-.530 for positive seals
Case in point...I've been trying to sell a decent set of 2.02 intake "J" heads with good springs and bronze valve guides that came with the 340 I bought....and there's been little to no interest. I don't think that's a coincidence.
You can still find those heads everywhere, why would someone buy yours when when they could have their own done and not pay shipping and not wonder what was actually done or NOT done to them?
Not only that, but you can buy NEW RHS heads that flow like mildly bowl blended j/x heads, have all the closed chamber crap that people think is gona make or break their combo AND have shaft mounted rocker setup on them.
